Judging by the appalling "Gear4Music" own brand guitar that some of our friends bought their son, they don't have much of a process. The bridge wasn't even in the right place to get it to intonate properly. I did the best I could with it, but it really was a piece of junk.
Don't use DV247 on principle:
http://theeccentricblog.blogspot.com/2013_05_01_archive.html
Coda and Peach are good but I don’t believe they do a full setup unless it’s necessary where as the above definitely do.
+1
A friend plays in some silly tuning that requires a mix of gauges.
Coda restrung his new guitar and did a set up for him.
Even the shops listed that do setups will go for a 'one size fits all' type of set up.
It might be fine, or it might be the opposite of what you like, unless you can specifically ask for a type of setup.
If you just want it to intonate and don't mind about a lower/higher action than you are used to then it is fine.
Best solution is to learn how to do it yourself- it isn't difficult and you need a minimal amount of tools.
You'll save yourself thousands over your guitar playing life.
Same goes with making cables up.
http://www.thefretboard.co.uk/discussion/57632/
He's an ex member.
Have a look for yourself...
http://www.thefretboard.co.uk/profile/2463/RichardsGuitars
I've used most already mentioned.
Very pleased with telephone updates between ordering and pickup, because I had to preorder. They asked what strings I wanted and how I wanted the guitar set up before the day, so it was all ready when I arrived. Then they let me have a play if the new guitar before I handed over the money. They were polite in dealing with me. I can wholeheartedly recommend them without hesitation. So if anyone from GV is reading this, thank you.
I've had assorted odds and ends (pedals, boards, mics, stands etc.) from Andertons (well packaged), GAK (often a bit random) and Gear4Music (usually well-packaged, but their own-brand stuff is very much built down to a price IME and in future I'll be spending the extra for pretty much anything else)
