http://www.geocities.jp/dgb_studio/2svari_e.htm#60
R.
Eqd Speaker Cranker clone
First, does your bridge pickup have a baseplate, and/or is there a separate ground wire to the bridgeplate? This will decide whether it's easier to make the bridge or neck pickup the 'upper' coil.
An option could be installing a muddle pickup like the guy from mogwai has done (among others)
The way it's wired is quite simple - the neck pickup hot wire needs to be connected to the bridge pickup 'ground' wire (which is now not grounded) on one of the rotor terminals on the switch. The bridge pickup hot wire goes to the volume pot.
You can then connect the 1 and 3 position terminals on the switch to ground or the volume pot to shut off one of the pickups.
Does that make sense?
R.
I put a push push pot on mine that adds the neck to whatever pickup selection I have on the 5 way when it's up.
If I'm in the bridge position that gives me bridge and neck together in parallel. I did try the blend thing at one point but didn't like it. I've tried most things with that Strat at some point. Ended up with a baseplate on the bridge pickup, which is connected to the middle pickup tone control, and the push push on the neck tone control to allow me to add the neck to any combination.
