I have a Gretsch Electromatic Dueojet centre block. Today whilst using it, I removed the guitar lead and the nut and washer of the jack came loose and the socket ended up inside the guitar.Fortunately I have, with the help of our PA guy, managed to fit it back. The problem was that that jack socket is short so only just pokes out the hole in the guitar. Makes it really difficult to grip it whilst putting the nut back on.
Any solutions to this if it happens again? I'll keep an eye on it now and keep it tight, but if it does happen I don't want to get stuck again.
If the thickness of the guitar side is too much for a standard jack, you may need a long-thread one - you can get these. If so you might actually need an extra nut on the inside as well to stop it coming through too far. If the jack is not a Switchcraft - it won't be if it's the original - you should probably replace it anyway, for reliability. Make sure there is a shakeproof washer.
I also usually put a small drop of superglue on the thread before I fully tighten the nut just to be sure. If it's a Switchcraft jack it will almost certainly never need replacing again, but if it does you can just heat the nut slightly with a soldering iron.
Rift Amplification
Brackley, Northamptonshire
www.riftamps.co.uk
