Forensic Guitar Wiring Advice Needed!
robwrightrobwright Frets: 738
edited July 2018 in Guitar
So I don’t know much about guitar electronics! Took a Strat set out of a Tele (wired for 3 single coils) and now I want to put some other pups back in! Trouble is, I don’t know where to stick me wires!
The following photos show show where I have cut the old pups out, leaving some wire behind and also labelled the ‘hanging’ wire. Even with this, I’m not sure what i’m doing! Both pots are push pull which I imagine brings the middle pup in (the switch is a standard Tele 3 way) but I don’t get it!
https://i.imgur.com/82y4c9g.jpg
https://i.imgur.com/PTBpJua.jpg
https://i.imgur.com/K94NryZ.jpg
https://i.imgur.com/pRKmRrw.jpg
https://i.imgur.com/bSoChIJ.jpg
Is is it an impossible task or is there someone on here who likes a challenged?
Thanks!!
  • FunkfingersFunkfingers Frets: 14553
    Well, you already know that the bulk of your circuit is regular Telecaster PLUS the volume push-pull to add the middle pickup.
    It is difficult to even begin to deduce the intended function of the tone control push-pull pot without a clearer view of its contacts and some information about where the red and black insulated wires used to be connected before they were cruelly chopped.
  • OilCityPickupsOilCityPickups Frets: 10602
    Jesus that wiring is a mess, a total rat's nest! Me, I'd strip everything off and start wiring again from first principals.
  • guitars4youguitars4you Frets: 14335
    best option in such circumstances - more logical to take this approach and less time wasted trying solve as is
    Is it a three pickup or only two pickup setup you are going to?
    Out of curiosity, what exact pickups used to be in the guitar? Single coils, noise-cancelling stacked-coils or something else?
    If the Bridge and Neck position pickups were RPRW, by definition, the middle pickup will be in the wrong relationship with one of the other pickups. If this is the case, it would make sense for the tone control push-pull pot to be phase reversal.
    If the phase and magnetic polarity relationships are correct, then, the tone control push-pull pot might govern whether the middle pickup is added in series or in parallel with the other two pickups.
    The third possibility was a Kill/Mute switch but the output conductors do not connect to the tone pot switch terminals.
    That's not actually correct: a reverse wound reverse polarity pickup will be in phase with a standard wound pickup by virtue of the fact that its reverse wound and reverse polarity. if it were simply reverse wound it would be out of phase, by reversing the magnetic polarity too it is then back in phase and acts as a 'humbucker' when selected with another non RWRP coil.
  • robwrightrobwright Frets: 738
    Thanks all! Sounds like i need to start again!
    @Funkfingers - it had three normal single coils but I don't remember what the push pull did!
    @TheGuitarWeasel - I want three pups (as below)
    Ideally, I want to get the usual Tele sounds (I've got a Bareknuckle Boss and a Dimarzio neck to go in) plus just the middle pickup as and when! Can I do that with a 3 way switch and a push-pull? If so, where would I get a wiring diagram? Could the push-pull be wired to take the Tele pickups out and just have the middle? I don't want the 'in between' Strat sounds.
    I'm thinking this:
    Switch position 1 / push-pull not engaged - just neck pup
    Switch position 2 / push-pull not engaged - neck and bridge pup
    Switch position 3 / push-pull not engaged - just just bridge pup
    All switch positions / push-pull engaged - just middle pup
    Is this a dumb idea? Any other suggestions? I want classic Tele sounds but I do love me Strat middle!
    edited July 2018 tFB Trader
    I don't really have time to work that switching combo out ... calling @ICBM !!!!
  • AlegreeAlegree Frets: 665
    Run the switch output to the push/pull on top lug , volume pot lug 1 on common lug, and middle pickup to bottom lug. Wire 3 way switch as usual.
    Thanks @Alegree - much appreciated!
