To get a proper P90 sound you need at least a humbucker sized P90 which can ape the bobbin, wire gauge and most important, bobbin shape of the original. You could rout out and use use an ashtray bridge that takes a humbucker and thus fit a HB sized P90.
I put in one of Ash's Alligator 90 pickups et voilà, search over. It's not AS full sounding as the P90 in my junior, but it's a wonderful sound.
@theguitarweasel - do you have any soundbites or any links to the Kayman and Aligator?
For a Junior sort of sound fit a HB sized P90 end of story.
Even when the pickup bobbin, coil and magnets conform to P90 specifications, the steel Telecaster bridge is going to add a bunch of metallic overtones to the overall sound. Fender's posh P90 Telecaster model guitars usually employ the short "hardtail" Stratocaster fixed bridge.
More anecdotally, it has been my observation from guitars of various scale lengths and construction methods that the best hosts for P90 pickups conform to Gibson scale length, glued-in neck and, sometimes, the bridge design.
I derive enormous enjoyment from a Squier VM Telecaster Custom II but it always loses out to a PRS SE which, in turn, loses out to a Gibson.
The scale length is an issue, but the OP asked specifically about pickups.
