Perhaps not the most exciting subject...
I've heard a few people joke about plywood guitars but I don't think I've ever come across one. Perhaps I've never looked in the right places.
Are they still around? Did Epiphone or Squier ever put out plywood guitars? Or is it one of those things that was solely the cheapest of cheap Chinese?
Also interested if they were made from multiple sheets laminated to each other i.e. true plywood, or more like a catchall term for a body made from multiple pieces of cheap wood and glued any old how?
And of course, lastly, did they sound truly terrible?
Once I fitted it with decent pick-ups it sounded pretty good....
Almost all the ones I can think of are true ply, with alternating grain direction. And no, they usually don’t sound bad - it’s not easy to tell the difference normally. Plywood guitars tend to sound bad because they were made to be cheap and are fitted with cheap hardware and electrics, not because they’re ply.
One of the exceptions are USA Standard Fenders from roughly 1993-2000, which are closer to a description of ‘blockboard’ - ie multiple roughly square-section blocks with veneers front and back. Some Mexican Fenders were also like this.
Ply is not necessarily a bad thing. Some cracking slide guitar tones can be extracted from dirt cheap guitars.
I think that it is a fantastic guitar & I prefer the feel & sound of it to a couple of £400-£500 Epiphone LP"s I have tried even as stock.
Looks identical to this one.
Whether it has any real effect on the 'quality' of the tone is difficult to say - as with the ply guitars, it's just one of a number of factors. They don't sound exactly *like* all-wood guitars, but the Talman in particular has quite a lot of fans, including some pro endorsements. Both the Talman and the Sonex are quite heavy though.
even the neck appears to be made of finely laminated strips, all bound together with a super-resonant glassy varnish. some are horrible, but some are fun players. i like mine anyway.
this one sounds good enough.
Much depends upon how snotty you want to be about laminates. The Gibson ES-335/345/355 body is steamed and shaped from laminated tone woods.
https://i.pinimg.com/originals/75/3a/2a/753a2aa33bfb44a5df480266836b3ac7.jpg
(If you don't already know, it's a Gibson Zoot Suit.)
the paint came away like egg shell from around the horns and bottom pin and it was clearly not laminate but block.
https://i.imgur.com/O7FqwmS.jpg?1
