Now experimenting with running Helix into 65 Princeton. At home volumes, not gigging.
Impressed but a few questions:
- Is the best thing to remove any IR or cab and substitute preamp for the relevant amp on existing patches?
- Is there any easy way to transfer settings from full amp/cab patch to same with just pre-amp?
- Is there any easy way without swapping and disconnecting cables to compare straight through just the guitar signal with the Helix signal?
- Finally what advantages are there to using a Helix with an amp with an effects loop and how does it work?
Thanks in anticipation.
2. No afraid not
3 can’t think of one other than 2 ab boxes, once you plug a guitar in to the helix you have a buffered signal
4 it means you can choose between running your real preamp and the helix preamps. You can also put some effects before the preamp stage like drives, compressors etc, and run delays and reverbs and stuff after the preamp. Definitely worth the trouble if you are using a real amp
By far the easiest option, and IMO the best is to use a FRFR speaker, then you don’t have all the hassle of 4 cables, and you get all the choices of amps and cabs without the colouration of the real cab
I do have 2 Yamaha DXR10s that I can route through ( They also double as PA for acoustic gigs) but there is a part of me that still misses a clean valve amp sound even at low volume that adds body and warmth. I am more than happy with just a great clean valve sound that can then be added to whether overdrive or delay, trem, etc etc.
This is my scheming/thinking for maybe selling my Princeton and going for a Victory or similar. At the moment it is only for home use as the only outside stuff I do is acoustic.
Any other amp that would be suitable in your opinion/experience? (Appreciating your previous advice which I do get of just using FRFR)
I use my helix direct in to a DXR10, still have a few valve amps that I plug in from time to time, but after the simplicity and flexibility of the helix, the tiny difference ( not improvement) in tone just isn’t really enough to make me consider incorporating a real amp in to my helix rig.
not saying doing so is wrong, but for me just using the helix is so much easier, and with not a lot of tinkering sounds just as good
Having said all that I would still like a valve amp at home for the occasional nostalgia factor and having sold all my pedals it seems sensible to utilise the FX from the Helix so an effects loop makes sense. Maybe a second hand Fender supersonic or a blues deluxe should do the job without too much expense and pass the Princeton on.
Thanks John A.
I closed the back of the Mustang a while back as bit of an an experiment to stop sound bleeding through to the drummer too much on tight gigs. To me it sounds better that way, but not sure if it would affect the amp if using with a Helix.
Thanks.
Guitar-->Helix-->Send 1 to Princeton-->FX out -->Return 1 on Helix-->Helix out to FX Return on Princeton.
This way you can use the Princeton Pre-Amp as another FX that you can place anywhere in the chain.
I run a Helix with a Mesa 50/50 and 2X2X12 Marshal cabs.
For Amp sims with L6L power tubes, I just use the Pre-amp models (the Mesa is L6L),
For other (EL84s, etc) I use the amp models without cabs.
I then have a second output going to my interface with a speaker sim for recording.
But bear in mind that small differences in level will sound like tonal differences.
I know some people disagree with me on this, but I don't think it's a terribly useful thing to test - get a sound you like with the Helix and don't worry about the direct sound potentially being a bit different. Unless you're very, very careful with your testing regime it's easy to make them sound more different than they are.
The Princeton does not have an effects loop. One of the reasons I am considering changing to a different amp with an effects loop. Just don't know if the advantages outweigh the cost and hassle.
If you're just using the amp as a makey-loudy-box (ie clean or darned close to clean) then it makes less difference.
I could go to Andertons with guitar and Helix but then if I did fall in love with the amp I'd bide my time for a used one to come up so not really fair on Andertons.
Princeton
Princeton with Helix effects up front
Helix-> DXR10
Use each of them when appropriate and enjoy them for what they are
Totally agree with Sporky. Who cared if the bypassed sound is a bit different, as long as it's not awful, which it wont be
Still have the odd lapse though
Not all effects loop are created equally, and they can often affect noise levels and quality too much, imho
