SOLD: Carr Bloke s/n015 £1,000 ono
dts67dts67 Frets: 195
edited August 2018 in Amps £
For sale due to lack of space/use is my rare Carr Bloke. If you like everything from Plexi to Hot Rod'd Marshall then this is for you.
Allegedly only 76 of these were ever made.
It's a two channel affair fitted with the optional effects loop. Build quality is amazing - totally point to point in that there are no tag boards or PCB'S.
Channel 1 is switchable between classic Plexi ( very touch sensitive) and hot rod JCM800/Friedman BE sounds.
Channe  2 is a lead channel with what is in effect a tube screamer in circuit boosting the mids and delivering a cutting lead tone.
The loop is not buffered but includes the loop driver pedal to adjust the send and return or as I do you can use a buffered reverb pedal.
Channel switch footswitch included.
This is not an amp for clean tones but put a strat through the Plexi channel you will get instant Hendrix.
It is currently fitted with a Jensen Jet ceramic. This was a bit of a find and really works with this amp but I will also include the standard Carr Elsinore speaker.
Pickup only on this one please but may be able to meet if not too far. Located close to Witney Oxon.
https://i.imgur.com/JhROzYb.jpg
https://i.imgur.com/NYZgbKx.jpg
https://i.imgur.com/MQefLBZ.jpg
https://i.imgur.com/2pdod9Y.jpg
  • dcgdcg Frets: 231
    Totally fabulous amp, and really underrated; should be part of the Carr legend. Found mine in Italy via a trade for my PRS SC 245...don't miss this opportunity. Drop dead looks and sound.
  • dts67dts67 Frets: 195
    Bump for the weekend.
  • ^^ What @dcg said ...
    I had the pleasure of playing through one of these at Sounds Great a couple of years back. Took along my LP and it was instant Lizzy at shop-friendly volumes.
    As I tend to require a genuine clean and crunch channel, I left it in the shop - but, it's a tone that's haunted me ever since. I also thought it would make for an excellent head conversion, and then whack it through a 2x12!
    GLWS - hell of an amp on sale here, folks.
    Bump
    Last bump before it goes in the loft for a while.
  • DrCorneliusDrCornelius Frets: 7231
    I’d love this , it’s just the wrong timing  for me financially unfortunately .  I had a Carr Mercury once that I shouldn’t have got rid of and from clips I’ve watched the Bloke sounds similar to the fully driven Mercury which is indeed a wonderful noise!
    Have a bump
