Strat bridge pick up
HootsmonHootsmon Frets: 15999
Pros and cons guys of havin' the bridge PUP wired, or not, to a tone pot
tae be or not tae be
  • guitars4youguitars4you Frets: 14454
    edited August 2018 tFB Trader
    100% wired to the tone pot for me - Many like tone for neck/middle + tone bridge - Eric Johnson mod as it is now known is tone neck + tone bridge so no pot adjustment on the middle
    Getting more popular is master vol + tone and the bottom pot now blend for neck + bridge together, or combination of
    But on hi-gain I find the tone pot allows you to slightly roll off 'fizzy highs'
    Easy mod to do - longest part of the job is removing the scratchplate
  • Adam_MDAdam_MD Frets: 3420
    I don't know of any reason why you wouldn't do it.
    I think it is fair to say that if today, 2018, was the launch date for a new guitar called a Strat, then the 5 way switch would have been standard and the tone pot wired to bridge as well - No reason it should not be
    The weird thing is fender still make a few models which don't have the bridge pickup wired to a tone pot don't they or have they finally sorted that out?  Even on the cheaper models of strat there's no reason not to.
  • HootsmonHootsmon Frets: 15999
    but some guys say it rolls of some "ooomph" and small volume drop
    I get that with a tele/esquire but not sure I'd want that with a strat bridge pickup.
  • OilCityPickupsOilCityPickups Frets: 10738
    I simply can't use a Strat without that mod.
  • HAL9000HAL9000 Frets: 9754
    I tend to have the tone rolled right back on the neck pickup, but not on the middle. I wouldn’t want them both connected to the same tone pot. I rarely use the bridge pickup on a Strat so am quite happy with it not connected to a tone control.
    more so on vintage replica models - less so on 'modern' creations
    Just fit a no-load tone pot. Drops out of the circuit when you don’t need it.
    I was actually planning on making a thread to ask about Strat bridge pickup.
    I'd always read people saying they hate it and that the tele bridge is infinitely better so, even though I've always quite liked the Strat bridge pickup (always connected to a tone pot but often play it on 10), I always thought that I should get a tele and the tone will be so much better.
    I borrowed a tele recently and find that while I do like the tele well enough, I definitely don't prefer it to the Strat one. It sounds very different, has more attack and is a lot darker sounding. It is obviously hotter too.
    I wonder if the specific Strat pickups I have - fat 50s - sound different to most? Or are there plenty of other people who also like the Strat bridge pickup?
    If I wanted to play styles that I'd personally use a humbucker for, but was forced to use a "caster" I'd take the tele over the Strat but obviously that isn't the case.
    Any thoughts on that?
  • richardhomerrichardhomer Frets: 24851
    edited August 2018
    The bridge pick-up on the Strat in my profile pick sounds great. It is connected to a tone control - which although I never use it - does roll off the ‘really’ high, high end. I too prefer a good Strat bridge pick-up to a Tele.
    The guitar has a lot of low-end played acoustically - which translates to the plugged-in sound - plenty of ‘woody’ depth.
    The pick-ups are CS 50s - which aren’t available separately - normal vintage-style output
  • rossirossi Frets: 1707
    I bought a cheapie Squier SE  which sounded terrble but after a drop in pickup height was much better.Not saying the  ceramic gut blaster pickups were top notch but good enough and very stratty .
  • HenrytwangHenrytwang Frets: 473
    I like my Stratocaster bridge pickup wired to a no-load tone control. I generally have it in the no load or off position but it’s good to be able to take off a bit of high end if needed.
  • RMJRMJ Frets: 1274
    You're doing it wrong. Neck pickup is where it's at on a strat
  • One nice thing about the middle and bridge sharing the same tone pot is that you don’t get double tone roll off when using both together. So, it’s brighter than the mid+neck position.
    I have a master volume/master tone, with a bass-cut on the third knob.
  • Treewig1Treewig1 Frets: 445
    Strats have tone pots?
    I used to think that way ... never used the bridge pickup .... and seldom used the middle. Nowadays a combination of a baseplate on the bridge pickup and wiring it into the tone control means I use the bridge a hell of a lot.
  • AnderzAnderz Frets: 30
    I got a noload pot on and I can turn the high end down. Before it was standard. The difference is cool to have and it is od that stays on my partscaster.
    Computer Shop UK Your PC Needs In One Place: https://computershopuk.com/
  • FezFez Frets: 536
    I did the mod on one of my strats but didn't like it so I reversed it.
    Don't touch that dial.
