Decent Strat hardware, bridges, pickups etc weigh a lot more than that for a Tele, so in the end loaded bodies often come out with similar weights, again, all things being equal (i.e. if timber is the same density).
Other things which can make a difference includes the quality of hardware (skinny cast trem blocks vs cold rolled steel, locking modern tuners versus klusons etc). Type of finish is also a factor - elsewhere people have weighed the poly finish when stripping guitars - around half a pound in the case of a Baja Tele if I remember correctly).
So, with similar density timber, if a Strat and Tele.are built and finished in the same style, with equivalent quality parts and finish, they will likely be quite similar in weight.
http://www.thefretboard.co.uk/discussion/89942/caspercaster#latest
I can't remember which forum, but someone used the heat gun method to strip the finish. Weighed the body first, peeled off the finish and then weighed both finish and stripped body. Finish weighed about half a pound. I don't know how much a nitro finish would weigh, but certainly less than half a pound! In fairness to Fender this was a few years ago, and a 2017 classic series body I picked up at the start of this year appears to be quite thinly finished, so maybe things have changed in recent years.
EDIT: it was over at TDPRI
http://www.tdpri.com/threads/refinishing-a-baja-tele.558376/
In general Teles seem very slightly lighter than Strats to me, but there isn't a lot in it and it's easily outweighed ( ) by the difference between individual pieces of wood.
The trem assembly is a major contributor to the total weight - especially considering how light a Tele bridge assembly is.
Think I might have compared the actual weight measurement to online figures though so maybe this Tele is just very light.
Would love a Strat as light as that as long as it sounded the same as mine. Suppose it doesn't really matter when I'm sitting playing it, just feels nice lifting it out of the rack.
Most vintage examples weigh between 7.5 - 8lbs - ‘really’ light examples are very rare.
Agree that some light weight Strats closer to 7lbs can appear to lack 'body' when it comes to the tone - pun intended - They will still be crisp, spanky and airy, but somehow not quite as big a voice - Not always, but often
builders se to agree that it is easier to find lightweight swamp ash, than it is to find alder.
My p bass is very light in the body, I wonder if I'm missing out on any tone because of that
Each example is unique as far as weight goes, pick one that plays nice and feels comfy to you.
My Strat is very heavy for a strat and being a hard tail too gives a very tight focused sound as opposed to the light airy springy sound some others do, but still intrinsicly strat. Getting hung up on 'period correct detail' or internet folk myth can have you missing some wonderful guitars.
