Hey all.
So I have a really old Ibanez Gio, thats been sat gathering dust for a couple years.
Worthless selling because I doubt I could shift it, so I figured I’d pop it down to Leigh Music co Monday to get it set up in drop c, so I can atleast play along to some stuff I havent been able to play along to in years!
I usually play hybrid 9-46 strings on my Esp’s, Chapman and Prs in standard tuning.
So I don’t like properly heavy and hard to bend treble strings. But I also don’t want then to be rubber bands in a lower tuning.
I’ve been thinking 11’s something? Or is that going to be too light?
The guitars a hardtail string thru body.
I usually play Ernie Balls, and I need to buy some anyway, so I was planning on picking a set up on my way and taking them in with the guitar.
I would also like to be able to raise the Low E (or C in this case) up to D, so I can play in standard Dgcfad tuning too.
I guess this would have been less complicated to say, I want it set up in Dgcfad but able to drop the D string to C on occasion. Lol.
Any advices?
(I’ve tried and failed many times to set a guitar up, I don’t know why or what it is, I just can’t do it, nothing works out).
The problem you may find is that the nut grooves might not be wide enough for those, especially the low strings.
Will take it along and see what can be done!
The set up is terrible, but hopefully that can be sorted.
The nut slot width seems ok, but there appears to be something I never noticed before, which is weird. The G string seems to sit a lot higher than the rest.
The neck relief seems minimal, but the action is highish, yet certain strings, the g, b and maybe d seem to choke past the 12th fret.. but if those strings are raised, I feel like the action would be way too high..
Then again the bridge, which is like a fender style 6 saddle job, probably isnt radius’d very well either.
Hmmm. I was hoping a basic set up would see it all good, but I aint holding my breath now!
But the easiest thing is to use www.stringtensionpro.com and work out what will be close to what you’re used to. It’s based on D’Addario strings but should roughly translate like for like construction.
My issue with the heavier Ernie Ball sets is they often do an overly thick plain 3rd string, for my own tastes a .019 is the thickest plain string I like. When you get to .020 and above the attack starts getting a bit duller, at least that’s how I feel about it. Most noticeable on the Not Even Slinky set which has a plain .024. It’s all personal taste at the end of the day though
So medium top extra heavy bottoms are looking good.
contactemea@fender.com
