If you are going to bathe the mechanisms in something to thoroughly degrease them, it would be wise to protect the tuner buttons first.
When I bought the guitar seller said that they didn't think the tuners were the originals; is there any way I can tell one way or another? I'm starting to use different tunings and it would be simpler if the tuners were easier to use. They hold tuning fine once it's found but getting there is a bit of a chore. So I'm thinking I'll give them some attention and if they don't improve, then replace them.
I sprayed degreaser and WD40 followed by some spray can lithium grease. The cleaning process didn't reveal any muck in the housings and after reassembly they are much as they were previously so I can only assume they are low quality versions. There's a lot of variation in tension when they're off the guitar - some turn very easily but most have a heavy action. Think I might have to upgrade.
If they are not original and the clean hasnt worked I would just replace. If they are old and worth saving I would try a bath next, and if that doesn’t work I would look to dismantle and rebuild with new gears if needed.
Instagram
Edit - just noticed the bit about the slack - think I'd go straight for replacements! :-)
