I've just taken delivery of a set of Fat 50s that were lifted from a recent American Standard Strat, but how do I identify which pickup is which?!
I'll only be using the neck and middle (in my HSS EBMM Silo Special) and am aware that the Fat 50 bridge pickup is wound slightly hotter than the other two, so need to avoid that one.
Two of the pickups I've received still have the black & white wires soldered together and one of them has a blue felt tip dot on the underside of one of the pole pieces, and I'm guessing these may be middle & neck. The loose pickup has a red felt tip dot on the underside of one pole piece.
The (eBay) seller had his local shop remove the pickups, so hasn't been able to help me with this, and I'll be having a local tech do the fitting for me.
Any ideas?
https://forums.fender.com/viewtopic.php?t=31220
I think you're right that the red dot is the bridge. The middle pickup is the one with yellow wires and no dot.
If you have no luck by tonight I'll open it up and double check the dot colours for you. It's the Fat 50s I have.
