It does make a difference as you’ve discovered, the channel the guitar is plugged into gets the full output of the guitar so is brighter, and the other one is loaded more heavily so is duller. So if you plug the guitar into the normal channel instead of the usual treble channel, the normal will be slightly brighter, and the treble channel slightly softer - ie there will be less difference between the two channels than the ‘standard’ way.
By using a Y-cable, Eric Johnson will get the brighter sound on *both* channels.
The cleans are better and it seems to hit that mid 60’s EC tone this way. That’s why I started looking for old pictures.
@martinw yes, I have noticed a difference in tone when I turn up the high treble side when I am plugged into normal channel alone. I thought that was interesting because it meant I could use the non plugged into side as a bit of an EQ.
What I will say is that I am struggling to find a use for my pedals other than Fuzz and modulations.
