Why are "clean" boost/ pre driver pedals so expensive?
AuldReekieAuldReekie Frets: 196
e.g. Mad Professor Simble pre driver, Xotic EP Boooster...................when you could use the volume on an EQ pedal to do the same thing?
Or am I missing the point?
  • dindudedindude Frets: 8540
    You’re missing the point. Both above you mentioned, and good deal more, add a distinct “flavour”. You’re paying for their flavour, if you like it. If you need several dB of pure clean boost then yes an Eq pedal or such will do the job.
  • AuldReekieAuldReekie Frets: 196
    Thanks for explaining this, cheers
  • slackerslacker Frets: 2256
    Eh lpb1 39 quid.
    They are not all expensive. However you pay more for flavour options build quality fancy paint point to point exchange rates etc.
  • SporkySporky Frets: 28787
    Some of the marketing bullhonky is very expensive.
  • ICBMICBM Frets: 72724
    As dindude said - most clean boosts are not truly clean, and it's the slight EQ shifts or harmonic distortion which give them character and make people prefer one or another.
    Ironically, a truly clean boost is not difficult or expensive to make, but will most likely be perceived as 'bland' or 'sterile' sounding. As mentioned elsewhere, a Boss LS-2 is (among many other things) an excellent truly clean boost, but you will see almost no-one using one for that.
    Thanks to all for replies/suggestions. Bought an EP Booster today (for a very good price new) after trying it out with my Tumnus Deluxe and Euphoria pedals. Bliss!
    the Mosky XP  boost is worth a very close look ...
    It really is. I have one and find the tonal difference rather pleasing.
  • 57Deluxe57Deluxe Frets: 7348
    edited August 2018
    simples:
    £11.60 new and delivered
    one of the best pedals I have ever bought - expected nothing got rewarded with tonnes of unfettered LOUD
    https://ae01.alicdn.com/kf/HTB1IyV9LXXXXXa.aXXXq6xXFXXXn/227079233/HTB1IyV9LXXXXXa.aXXXq6xXFXXXn.jpg
    <Vintage BOSS Upgrades>
  • John_AJohn_A Frets: 3775
    Yes.  Sounds like an EP booster for 15 quid, can’t fall off
  • Pete24vPete24v Frets: 235
    I bought one, and it does indeed sound like an EP Booster.. The issue with mine is the horrible pop/bang made by using the switch.
    Well, I've splashed out on an EP Booster; attracted by getting one new for £99
