Bias pot for princeton.
jacksparrowjacksparrow Frets: 673
Hi Folks, Any one know about putting a bias pot in without drilling any holes in the chassis of an original blackface Princeton reverb.
I am going to get the tech to replace the cap can also.  Anybody know where i can buy the suitable parts.
Thanks in advance.
  • RiftAmpsRiftAmps Frets: 3189
    Modulus stocks the direct replacement cap can (Mallory) that works really well and any competent tech can install a non-invasive bias pot
    Rift Amplification
    Handwired Guitar Amplifiers
    Brackley, Northamptonshire
    www.riftamps.co.uk
  • ecc83ecc83 Frets: 1643
    Overkill I am sure others will say but I would use a fully enclosed multiturn trimmer (Maplin USED to have them!) . Mounted on a piece of stripboard  (aka Vero) then fix that in using heavy gauge solid copper wire, internal of TV coax is perfek.
    Make sure it is wired so that a fail "open" gives maximum bias volts not minimum!
    Dave.
  • Thanks guys, will order 2 x cap cans from modulus.
  • DJH83004DJH83004 Frets: 196
    Just a quick point, the can capacitor used in the Princeton is multi section, (20/20/20/20 uF), you don't need two.
  • Modulus_AmpsModulus_Amps Frets: 2603
    I fit Piher trim pots for bias adjustment, they are big enough to not be too fiddly, but small enough to be fitted directly on the board
    Why do you want to install a bias pot anyway? The amp has survived 50+ years without one and I bet it hasn’t suffered because of it ;)
    Rift Amplification
    www.riftamps.co.uk
  • I am getting the cap cans done, as they are the original ones, and just want to be able to bias my amps myself, with my bias probe.
    Also one sounds a bit gravelly to me probably a cold bias.
    @Modulus_Amps  ; do you sell them phier on your site?
  • ICBMICBM Frets: 72831
    Exactly.
    The Princeton is not a high-stress circuit for 6V6s - by guitar amp standards anyway - and biasing is not critical as long as it’s in the right range.
    ICBM said:
    Exactly.
    One side-effect of home biasing a PR is the inevitable e-mail to a tech enquiring why the tremolo is now weaker :)
    Rift Amplification
    www.riftamps.co.uk
    RiftAmps said:
    ICBM said:
    Exactly.
    But how would you know until you have tried?
    Most guys that build kits want adjustable bias, I suppose to satisfy themselves that they have the amp tweaked just the way they want it. there is no harm in doing it even if not needed and is part of the learning experience.
    @jacksparrow yes I do have some Piher trimmers, they are also available at other electronic suppliers. depends on what value you want to fit.
