Marshall Valvestate 8080 question
jdbwalesjdbwales Frets: 314
Recently got one of these for nothing and I’m fixing it up (replaced pots, cleaned connections etc) - it’s a stunning practice and grab and go amp, fair play.
 My issue with it at the moment is that I need the fx loop to stay at the 0db setting rather than the -20db as I have the fx at 100% all the time.
The latching micro switch that changes between these two settings is damaged and doesn’t work properly - realistically I’ll never need the -20db setting, so if I was to desolder and remove the switch from the circuit entirely, would that leave it permanently on the 0db setting (normally the switch is on the ‘in’ position for 0db) or just cock things up mightily? I can always order and fit a replacement switch, but would removing it entirely save me the bother and run the loop permanently at 0db?
Cheers!
  • KeefyKeefy Frets: 2301
    The schematic is easily available as a pdf. As far as I can tell, you just need to hardwire the fx send to the junction of R17 and R18, and make sure the junction of R43 and R20 is not connected to earth.
  • jdbwalesjdbwales Frets: 314
    Sounds easy enough and thanks for the reply - is there an idiot proof way to do this? @ICBM ; have you done this at all? Sorry to tag you in, it’s just that you know, well, everything.
    My best tip is to take photos and make sketches as you go, also use a meter to check what is connected to what. If it all goes tits-up you then stand a better chance of getting it back to how it was.
  • ICBMICBM Frets: 72574
    lol
    Actually my advice would be to replace the switch properly - it’s not difficult and you need to have the amp apart to hardwire it anyway. It’s not impossible that one day you will want to put a pedal in the loop which won’t take 0dB.
    If you can’t find the right type online, Marshall are very helpful with parts, and failing that I may have one - PM me if you can’t get one elsewhere.
    Thanks both, sounds fair enough - I’ve bought 2 switches from eBay that seem to be correct so they’re coming this week, are these the right ones?
    https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F253172887770
    Will just install a new switch if so!
