We're looking at a house. We like most of it, the downstairs rooms are nice, lots of room, all freshly done up, new kitchen etc. Upstairs is a possibly a little small but it's not a problem, 3 bedrooms, two of them are double, just not huge double.. new bathroom, no shower, but plenty of space to put a bathtub type one in.
The problem is.. it runs on 4 of the big orange gas bottles (uses 2 at a time i assume with an auto changer thing)
I'm not sure i like this, not being run on mains gas.. In my mind it would be more expensive, less choice of supplier, and generally a hassle.
I've looked into it on internet, and would you believe it, the internet doesn't agree. So i'm putting it to the fretboard grand council..
Is this an issue? Are my costs likely to skyrocket with this? Anyone have any actual (semi-recent) experience of using gas bottles for property?
Thanks
Even if you own and run a plant hire business, the gas provider will insist on excavating and back filling all trenches themselves. (Elf an' safety!)
I live in a rural county. Many homes have either bottled gas or fuel oil containers. TIP: Thieves prefer fuel oil because it is portable. Propane needs to stay in the pressurised vessel. It would take a fork lift, telehandler or HIAB lorry to purloin a proper gas container.
Somebody I knew through work heats his home on fuel oil. He reckons that demand is seasonal and that there are deals to be had by ordering well in advance of when you need the fuel.
Actually, those steel vessels are bloody difficult to break. Corrosion takes decades to work its magic. Only Wile E. Coyote would try an oxy-acetylene torch or an angle grinder.
Worryingly, this was my very first thought as well.
If you've ever seen the Bourne Identity, you will know that blowing one of those bad boys up, will create a perfect diversion. Should you happen to have a sniper assassin, somewhere outside your gaff.
I have stayed in a property heated on fuel oil and they ran out of oil. Turns out the suppliers don't run an emergency service so we shivered for a few days until the next supply run came. I guess propane is much the same, just needs a bit of thought to make sure you have enough. But external gas tanks are common on houses all over the world so I don't think it would stop me.
“I wasn’t flirting with her. I didn’t even mention that I work in propane!”
We're with Calor but there are a few other suppliers, so you can move.
Price wise it's not too bad, a bit dearer than mains, but not a big deal. The price of living in a rural location.
We have a telemetry system, so they come and fill it up when it needs it, without us having to do anything.
I'm sure they are generally very safe but thought it worth a mention.
Houses with mains gas blow up too.
Remind me to email you about that amp. Hope you're well.
Having said that, I grew up with LPG from a big tank. It is more expensive than mains gas, and fuel oil systems.
I'm not sure how the costs add up now, but a big tank used to be cheaper than bottles, and whatever company supplied the tank/gas would also carry out the required testing on the tank when needed, but you were tied into the one supplier unless you got the tank swapped.
Provided it's serviced correctly, there should never be any safety problems.
All good here thanks. I emailed you a few weeks ago, hope it got there?
Wouldn't let it be a factor in whether you buy the house tbh. Not a big deal. As has been said, you just need to be a bit organised in ordering your fuel. We have oil, its very straightforward to manage. Also are a lot of p[alces round here not mains connected to anything but water and electric. Gas & oil are common. No issues.t
There are price comparison sites too for your fuel.
Boilerjuice is one I use.
You may find that there is a gauge on the gas tank too.
Phone around and check T's&Cs before signing !
