Wonky fender knobs!
stuagustuagu Frets: 334
So, im being stupid here, i bought some white fender knobs
 ( vintage amp style)  for my telepartsocaster. When i put em on they just wont sit anywhere near straight, as i tighten the screw it cocks over to one side.... what am i missing? Help? Thnx
stupid from kent :)
  • GluedtoMusicGluedtoMusic Frets: 74
    edited August 2018 tFB Trader
    You might have larger imperial sized knobs with smaller metric sized pots.
    Supplier of Gotoh, Fender, Gibson, Faber, Schaller, Hipshot, Floyd Rose, TonePros, Graph Tech, Hosco luthier tools and many more.
  • SteveRobinsonSteveRobinson Frets: 7039
    They are made for 1/4" solid shafts. If yours are narrower you need some adapters.
    https://www.allparts.uk.com/products/brass-sleeves-for-split-shaft-pots
  • ICBMICBM Frets: 72445
    If you’re trying to put grub screw knobs on split shafts, wobbling is the least of the problems - if you tighten them too much on the side of the shaft you will fold it in. If this has already happened, trying to straighten it will usually break the shaft, although if you’re *extremely* careful and lucky it can sometimes be done. (Try forcing a knife blade down into the gap, without levering it sideways.)
    It can be made to work reasonably well if you either make sure the screw presses directly on the gap in the shaft, or fill the gap with something solid (a piece of cut-down pick is ideal if you have the right thickness), but a solid-shaft pot is always better.
  • stuagustuagu Frets: 334
    Thnx for your help
  • HenrytwangHenrytwang Frets: 471
    As has already been said, you’re trying to put imperial knobs on a metric shaft. All is not lost however, just put some sort of spacer in the slot if it’s a split shaft and wrap a piece of masking tape around the shaft in order to make it a bit bigger if needed.
    I told you i was doing something stupid!!!:) thnx
    These pots are mismatched anyway, so if i get a new loom or pots but with 1/4" solid shafts itl save farting around? Thnx
    Yes, if you want to use those knobs it's by far the best solution.
  • 57Deluxe57Deluxe Frets: 7339
    if you have spit shafts twease them in a notch and try to reseat your knob
    <Vintage BOSS Upgrades>
    edited September 2018
    https://i.imgur.com/x1whcuL.jpg
    all done with new pots... thats better ! Thnx for advice once again.
