There's nothing for it, I'm going to have to put some guitar cases in the garage for space reasons. I've got shelves so they'll be off the floor and not against the wall, but the garage is single-skinned. I'm worried about damp getting to them.
Running a dehumidifier in there constantly is one option, but it seems like a waste of electricity. What else can I do to protect the cases against water damage? Can you get giant airtight bags?
My YouTube channel,
Half Speed Solos: classic guitar solos demonstrated at half speed with scrolling tab and no waffle.
What about the loft?
I would highly recommend doing that, or at the very least wrapping and taping them as completely as possible to be airtight, or they will absorb moisture and develop mildew.
https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.co.uk/ulk/itm/132510939258
Would it be worth putting in some packs of silica gel or dehumidifier packs etc for good measure? Plenty available on Amazon and some can be dried via microwave or oven and then reused? You could then unpack the hard cases periodically to see if the silica gel or dehumidifier packs have worked and dry/replace them occasionally?
You can put some bicarbonate of soda in there, that should kill some of the odur. I cleaned mine up and sold it. Then bought a Hiscox.
Here's my Martin case, the biggest one I own, fitting comfortably inside one:
I've put a few cases in the garage already but a few days later I noticed that they'd let in some air. The zips are very long and have to be pinched shut, so you have to be careful to get a good seal. Anyway, I'm pretty sure they're going to be fine.
I also bought some indicator silica gel packets from DGR products. They're reusable and they change colour when they're saturated, so I'll be able to check on the cases periodically and see how much moisture they're being exposed too.
