Absolutely love it
Definitely sounds better than AF2
Fan still stupidly noisy though, had to fix that myself
I got a similar reaction with the AF2, even though G66 had fitted a "quieter" fan, it was still unacceptable. I replaced it with a quieter one, with lots of rubber mountings.
In the end I did some research and found that:
With the AF3, since it's new I am wary of saying on the forum what I would do - in case I ever need to reverse it to get it fixed for any faults.
Note that the AF3 is now vented, so that "design decision" seems to have been reconsidered.
Here's what one person did with a bigger fan: see post 187 here: https://forum.fractalaudio.com/threads/how-loud-should-the-fan-be.137617/page-10
What I did was to take that aluminum plate, remove the fan-mount grommets, and fit this lot:
https://smile.amazon.co.uk/gp/product/B00KF7T9MI/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
https://smile.amazon.co.uk/gp/product/B00KG3KUK6/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
I then slowed it a little with one of these: https://smile.amazon.co.uk/gp/product/B00KHU1OW6/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
and also used the grommets to slightly insulate the plate from the bolts attaching it to the PCB
It's now quiet enough. Ideally I'd try to find a less rigid way to mount that plate to the PCB, since it transmits vibrations
£2700 + power amp + foot controller is utterly mental money though. That's going to be pushing 4k.
Nevertheless, I still maintain that my old FX8 MK1 had some of the best verbs and delays Id heard... and def THE best looper
Does the fan speed vary with temperature?
PCB has a 3 pin connector, not the clever 4 pin ones in some PCs, the AF3 is wired for constant fan speed
You can probably buy some thermistor set up to vary the speed, but that kit I bought just drops the voltage (and therefore speed) by a constant amount
Yeah, I was thinking a thermosistor setup would be useful, but you'd need to find one with the right activation temperature.
also some people commented that stock fans sometimes slightly varied in speed and that this annoyed them more than a constant drone at a fixed frequency
