Really not much of a pickup person so my knowledge extends as far as knowing that I have them in my guitars...
I've always been a rock/metal person but recently I've taken my playing back to basics and really gotten into playing blues.
The humbuckers on chosen blues guitar are pretty hot. Usually play using the neck pickup, so can anyone recommend something a bit more suited because apparently all great bluesmen are totally obsessed with tone and gear and stuff. That's why I'm playing on a superstrat, a classic blues machine..
Don't really have much to splurge with, and whereas I'm enjoying it lots at the moment and it has totally reinvigorated me.. I'm aware it may still be a passing fancy.. so low low budget
So uh.. what should I look for in a bluesy pickup and what should I check on measure ents and stuff?
This ramble has been bought to you by Luttis. Carry on.
http://www.rabswoodguitars.co.uk/
https://www.facebook.com/RabsWoodGuitars/
My Youtube page
Also, have a look in the parts for sale section as sometimes @TheGuitarWeasel or @Alegree have a clear out and might have something suitable at a good price.
I’ve never known a pickup that’s too hot for blues if you back it off a bit and the amp is set sensibly.
As I said I don't know pickups, but after much fiddling that's that my unknowing mind decided it might be pickup related..
Slight confused @LuttiS as you mention humbucker, then Strat, so not sure what your set up is
On a Strat, something like a Hendrix inspired 69 in the neck sounds different to a formvar wound SRV style pick-up with alnico 11 magnets - the 69 is more transparent with less mids, almost scooped - The SRV has fatter mids - Both are crisp and funky - Both sound like Strats but in a different way
If a humbucker then anything paf flavoured is probably the best place to start
Thanks all, will have a fiddle and a browse
You could also try lowering the pickup a bit to change the sound....
My Youtube page
Feedback
Not sure on the pots - it will be stock on what was a fairly cheap 12yr old guitar. Volume roll off isn't great - but there is a difference.
Also noticed the pickup is a bit high, so will give that a lower too
