As it's collection in person you'll be able to check it all out before handing over any cash so may be worth a punt.
contactemea@fender.com
Some modern Telecasters have graphite paint and a soldering lug in the pickup cavity as part of the screening BUT there is no reason whatsoever for a star washer to be in there. I conclude that bridge mod was performed by somebody who does not claim to know much about guitars.
IMO, a battered Mexican Fender has gigging potential. £250 might be a fairer price. It will then need some attention and some money spending to get the best from it.
The six saddle bridge segments tend to get dragged about somewhat by string tension. Having the height adjustment grub screws set on the cock does nothing to reduce this.
Look at the seller's third photograph. There is a gap between the edges of the neck and the pocket. (Space for several Rizla papers!) Worse, the gap appears to widen towards the bridge. With the pickguard unscrewed, the neck has a chance of coming into correct alignment.
If the evidence before your eyes does not convince you, perhaps, having @ICBM or @SteveRobinson post the exact same opinion would make it acceptable?
And that bridge is wrong for the guitar - it should be a modern flat one with 'strat type' saddles... the guitar would have looked like this originally:
https://cdn8.bigcommerce.com/s-dks6ju/images/stencil/1280x1280/products/6930/64212/2__62749.1431620602.JPG
So yes, the bridge has been changed by someone incompetent.
I think the alignment problem is cause by the saddles being slightly narrower than the originals, not the neck joint - notice how it gets worse as you go across the neck from high E to low E, with the gap between the E and A strings being the narrowest.
