More commonly, it will just sound bad, but it's not a good idea to try just in case - if it feeds back outside the audio range you won't be aware of it until you try to play something, and the damage can have happened already.
It *is* safe to simply connect the output of an external preamp, multi-FX with distortion or whatever to the amp's FX return, *without* coming from the send first - because there is then no way the signal can feed back to the input of the unit.
I only use this if there's another guitar player in my band, which there is at the minute. I use a badcat hotcat 30r. If I was only using the clean channel I'd pop the boost up front after the od pedal.
Everything else I prefer in front of the amp.
