I'm thinking is was the board though because the last two songs we did I plugged straight into the amp with no fx and it seems fine. Something wasn't working well with the board but as mentioned I've checked everything now I'll have to see if it happens at rehearsal this week
NB - I had issue with a dying power amp valve that did exhibit intermittent volume drops then finally arced ..
Q- did you consider power feed at venue ? - are you using a power regulator to amp / board ( Furman or similar ) ?
If you cant repeat fault at home - suggest using different sockets at venue - I'm sure I'm not only one to experience power issues at bars / clubs / rehearsal rooms - inline surge / circuit breakers are worth considering
otherwise - is your fx power supply ok - got enough headroom for all fx etc ?
good luck with fault finding
For something like this, I think you have to adopt the HAL9000 method: just keep using it all until the problem manifests itself again and you can track it down. Then, having done so, kill the crew and merge with a monolith orbiting Jupiter.
Bandcamp
Spotify, Apple et al
Its likely to be a dodgy patch cable still.
