I have a Sheraton II but as it's a 1989 model from the Samick factory, it's going to be different to the new versions.
Biggest differences of the two you are considering, aside from the Sheraton being a bit more 'ornate', are:
The Riviera P93 has 3 P90 pick-ups, whilst the Sheraton has two Humbuckers with coil-tapping (it also has a graphite nut). So for tonal versatility the Sheraton is likely to have the edge by giving you both fatter humbucker and thinner, brighter single-coil tone combinations.
But this depends on the tones you like - P90's will sound different and can be very warm sounding, albeit a little brighter than humbuckers, but being single coil they can also be noisier, especially with higher gain/distortion tones under lighting, near electrical equipment (eg computers) etc.
The P93 has a bigby trem - so if you need a trem, then the P93 will likely be a better fit - as the Sheraton Pro is hardtail. You can fit a Bigsby to the vSheraton but that's more expenses and needs to be fitted properly.
The fretboard inlays go all the way down the neck on the Riviera, but on the Sheraton they (including side dot markers) stop at the 15th fret which can be disconcerting for some players.
Both have a solid centre section with hollow 'wings' - the advantage of this design is that you get great semi-acoustic tone but you don't get the feedback problems often associated with semi-acoustics that are hollow throughout.
The Sheraton comes with Grover Machine-heads, the Riviera has Wilkinson machine heads.
Both are very nice guitars but you need to play them side-by-side to see which sounds & feels best to you, and consider how you're likely going to be using it.
In case you haven't yet seen them, here are the official marketing vids for both:
I will only add that it might be worth seeking a pre-owned Yamaha Yamaha SA503 TVL Troy van Leeuwen Signature model. Its switching system should prove quicker in use onstage than the three volumes and one master tone layout of the Riviera P93.
Humbuckers. No sissy coil splitting.
Feedback
https://images.richtonemusic.co.uk/product/YYAMAHA62214b.jpg
