There's a lot of talk of quality and reliability lately, and I'm really interested in what people have got to say. For me as a gigging musician build quality definitely comes into the equation when looking at amps.
I know once you get into the higher end big names like Mesa, Bogner etc then quality goes up, but I don;t know about the more usual brands.
But I'm not a tech, so i wouldn't really know what's good and whats not. I know for example that the marshall vintage re-issues are great, but I wouldn't be able to comment if the mini jubilee was the same quality as its big brother, their new DSL range, and how Marshall's core models like DSL and Origin holds up against the new Orange terrors for example.
So I was hoping people would chime in with their experiences and opinions.
I reckon the usual suspects are -
Marshall
Orange
EVH
H&K
Engl
Peavey
Blackstar
Fender
Does anyone have any input into quality fo these often seen big brand amps??!!
I shall be following this with great interest!
Dave.
Not sure you can lump everything from one manufacturer in together. I'll use Peavey as an example, as I've owned the pile of junk that is the Classic 30. The Classic 30 is a horrible design, but the Classic 50 is much better. They are two amps in supposedly the same series but are completely different.
Marshall have had variable quality over the years from what I've read. I don't have a lot of personal experience of that, so I guess we are waiting for @ICBM to contribute.
I’m assuming you mean valve amps so I will stick to that...
Marshall - vintage reissues good, everything else less so. The UK-made JCM2000 DSL/TSL series has some fairly major issues, but the newer Vietnamese ones seem better. I haven’t seen a Mini Jubilee yet other than pics, or an Origin. The company is good for customer service though.
Orange - everything I’ve seen so far is very good. Problems other than valve failures are rare - the only definite fault I can think of is that the AD30 has a poorly located standby switch which tends to blow rectifiers.
EVH - only seen one, but it seemed well-made. It was with me to try to fix the notorious channel volume balance problem, not because it had died.
H&K - not seen too many of these either, but the build quality doesn’t seem too bad. Some models are excessively complex which can make troubleshooting difficult.
Engl - I have seen quite a few of these. Not impressed - poorly designed and built, and often expensive to repair due to the way they’re put together, and in some cases using unique parts.
Peavey - like Marshall, very variable. Some excellent, some terrible. The C30 isn’t actually the worst - the new-model Valve King is. I’ve had one of those that was unrepairable due to a burned-out PCB that Peavey wouldn’t supply a replacement for. I much prefer their solid-state amps...
Blackstar - well-made, but the widespread use of surface-mount ICs is a nuisance, and there are a couple of known faults with the older models which could be difficult to fix. The company is good for direct customer service though.
Fender - generally good, with one or two problem models... the surprisingly badly-made and overpriced Blues Junior especially. Some of the bigger and more complex ones can be a pain to work on.
Does that help at all?
As you probably know, the amps I've used a lot are jcm800's and a hand wired orange, so modern amps by comparison seem to be a total minefield and it's less easy for me to tell if they look well made to my untrained eye!!
I was told to keep away from PCB amps, and to my untrained eye a lot of modern amps seem to look a bit like the way computers are made with PCB boards and ribbon connectors. It just seems less easy for me to tell what looks well made.
ICBM was, as usual honest and fair. I only know Blackstars of course and even then I have not worked there for some years but I don't hear or read of many reliability problems. SMT is the price you pay for "bells and whistles" at reasonable cost. I didn't like it either!
The fact is, anything with a valve in it is going to fail at some point. The test of a design is how well protected the rest of the circuitry is WHEN a power valve splarts and properly "worse case" rated components add cost the punter rarely appreciates.
Customer service is important and I am glad IC thinks Bs are good in that area. Personally I would like to see much tighter consumer law that made companies more liable for long term service. Might put a spoke in the "cloner's" wheels!
Dave.
Interesting thread, totally agree with IC’s summary, I also get my fair share of older Fender HRDs with the LV +/-15v supply rail dropper resistors and zeners de-soldering themselves due to excessive heat, and of course the valve bases.
Have just done a straw pole of the amps I currently have in for service / repair: Engl Screamer 50 combo, Mesa Tripple Crown 50, Orange Rockerverb 100, JCM 800, DSL 401, Laney VC30, Twin Reverb reissue, Badcat, Hotcat 100 and Sound City SC30. In my humble opinion the worst one to work on is the Mesa, I dread them, getting the main board out to change relays, caps etc. is an absolute pig. I really like working on Orange amps, and older Fenders / Traynors with eyelet boards – a dream.
I pretty much concur with the above.
Some random observations based on our repair work.
I've had several H&K amps through and they can be a pain to work on; they are quite fiddly to take apart, and the valve "protection/ auto bias" circuit can fail, rather defeating the object of implementing it in the amp.
MESAs vary from being OK to work on, to being a total pain to work.
The build quality of ENGL amps is not that special; for example several models have the output transformer mounted onto the main PCB!
I also had to "unmodify" an ENGL Savage 120, and the factory couldn't supply me with a schematic as they didn't have one.
Peavey Valveking is into a veritable pain to work on:
https://jpfamps.com/peavey-valveking-100-guitar-amp-repair/
Older Laney amps are reasonably well built, more modern offerings are not great. Some models are a total pain to work on, eg Laney TT100H
Blackstar are pretty well built (although they have very small output transformers), can be a pain to work on, and a lot of the one's we've had in have had odd faults, which have been time consuming to find.
We change more transformers on Marshall amps than ALL the other brands put together by a significant margin.
Fender amps are generally well engineered and were faults have been identified in models, then these are corrected in newer editions on the amp. The HRD / Blues Deluxe looks a real bargain 2nd hand.
Orange amps are well built, and generally the only faults we see are valve failures (in valve amps!) and blown output devices in the smaller SS amps.
