Following on from my head scratcher....
..I have discovered that the Ghost system is the issue. The shielding didn't work. The board itself is foo-barred. It got to the stage where it actually stopped amplifying anything other than the interference and thus is Kaput. Seems also that the "summing board" that takes the 4 individual piezo saddle pickups and turns them into 1 "hot" and "ground" connection was also knacked. To be fair, it's 10 years old so it's had a good run.
@ICBM - turns out the head scratcher was knackered hardware!!!
So...
I'm going to redo the innards completely. I will need to use a new set of Ghost ABM Piezo saddles and a new summing board to get my piezo output back to Hot and Ground. They are ordered and hopefully on the way soon.
My experience of actives has been mixed - but universally I've been impressed with the East Preamps - the man makes some lovely kit and I have a P-Retro in my ACG as an upgrade. So - I really would like to go East. This also means I'm using single manufacturer and single system. This should be much better and as
@ICBM will attest - it cuts out a lot of the crap by using a single system.
I need to call him to discuss, but he does seem to be a difficult chap to get hold of.
I think the way to do what I want to do is to get an East MPM 02 Piezo Mag mixer - which I can either use to mix the Mag and Piezo directly, or use it to preamp just the Piezo signal and output to something else.
I also want to have an active boost circuit for the Mag - preferably his Uni-Pre 3 knob system. Interestingly this allows two pickup inputs which can be mixed on the vol board by two 12db trim pots. So I could either blend using the mixer on the MPM-02, or go from the MPM-02 with just piezo and blend on the Uni-Pre 3 knob.
Controls would thus be:
Vol/Blend Pot - UP3
Piezo Tone (high freq roll-off) MPM-02
Mid Freq stacked knob with Mid Freq Sweep - UP3
Treble/Bass stacked knob with Pull for Bright - UP3
Switch 1 - Active/Passive
Switch 2 - ??
So - I'm a little unsure as to how to plan the details tbh - I have a spare switch hole at the moment - now I could get a different 4CW Jazz pickup with split or stacked coils and have a series/parallel switch in there, or I could put it as a power on/off switch and forget all the crap with the barrel jack and plug switching. Hmm.
Similarly, do I keep the piezo on the MPM-02 and then put the mags through the UP-3 and mix them on the MPM-02? That means the blend on the UP-3 is not needed, and I don't get the EQ on the piezo either (the tone on the MPM-02 for the piezo is purely for harsh treble roll off)
My preference would be:
Piezo -> MPM02 -> UP-3 input 1 (with tone roll off as knob 2)
Mags -> UP-3 input 2 with Vol/Balance Mid/Sweep Treble/Bass and active/passive switch
Out to the jack with switch 2 as an on/off kill switch.
I know
@Andyjr1515 has done an MPM-02 before so would welcome your thoughts, Andy.. also anyone else that might have a clue WTH I'm trying to do....
Since you like East products, begin by seeing what pre-amp systems he makes that might be applicable to your instrument. If East recommends a particular make/model of piezo saddle element to match with his buffered PCBs, follow his advice.
Plus, I can’t find anyone else that does ABM style piezo saddles
.....ah shit
Don't get me wrong. I think Graphtech is a good Company and make some good products. But to let their very expensive and powerful systems to be entirely dependant on such a cheap and unreliable bit of tat is utterly shoddy. Graphtech - you are better than this! Bl***y well sort it!!!!
The last system I installed, I just snipped all the piezo wires and soldered them. Only way of making it work. Outragreous.
Based on your experience as well as my multiple ones, I will contact them AGAIN.
I guess the big question is how I configure an easy setup to get it to do what I want?
Pending a solution from him, it means my final issue is these damned piezo saddles and wiring them together! They are really small little buggers and I'm a bit concerned my soldering isn't up to it - due to the routing they have to be done post install though. Gah.
I don't generally get het up about such things but it is commercially poor at best and negligent at worst not to fix it.
As the piezo wires are so fine and there are only four that would be wrapped together - and bearing in mind that the pre-amp is a screw-block connector? - then your idea is probably a good one
