I would draw the known dimensions out full size from the front, should give you all you need
Instagram
Its an acoustic, 6 string guitar/ukulele crossover, so the bridge can be any size as I still have to make it.
I understand that i can get most of the internediate dimensions from my drawing (currently full size with body outline, nut, scale length with 14fr body join), but i dont know where to start for the string spacing at the saddle, and therefore the taper of the neck.
Cheers,
Adam
Instagram
Check this build out, different scale length (20"), but may provide you with some other dimensions that you're looking for.
Band Stuff: https://navigationofficial.bandcamp.com/album/silhouette-ep
That link is excellent, and the little sound clip superb.
Cheers,
Adam
P.s. I now have the hornbeam b&s thicknessed to about 2mm, and the top simillar. The hornbeam looks stunning.
Your life will improve when you realise it’s better to be alone than chase people who do not really care about you. Saying YES to happiness means learning to say NO to things and people that stress you out.
I did as you suggested when i built last years' mini guitars and it worked well, and i'll do the same for the short-scale bass im also building for christmas But the uke is different
Cheers.
Adam
Instagram
Cheers,
Adam
My original post was because i didnt know what the string spacing at the saddle would be and i didnt realise that a standard guitar width would suffice.
Again, your patient advice is greatly appreciated.
Adam
