"Line" female jacks are notoriously unreliable. The odd click or signal loss in an input is a bother, in a valve OP stage it can be disastrous.
The ONLY free socket I would use would be the Nuky locking jobby. Not cheap but then neither are OPTraffs!
Personally, as a get out, I would just use chassis jacks and gaffer.
Dave.
That's just my preference though.
Turns out there is an H in Haych! ~ Sporky
Bit of trading feedback here.
Try to avoid anything that has additional plug and socket connections between the amp and at least one of the cabs - you don't want to leave the amp with no load if something breaks or a plug gets pulled out.
If you must use a line socket, as ecc83 says *only* the Neutrik locking one is suitable, both because it has a much higher current capability and because you can't pull the plug out accidentally.
so I’m thinking either mod my cabs which don’t have this ability (Bogner cubes), or see if someone can make Y speaker lead with one end male and then through to 2 male connections
