Tele partscaster WITHDRAWN change of plan
Decided to put this up for sale as thinking of picking up a little THR practice amp.
This has a squier affinity body and a harley benton TE80 neck (the prince copy) which is very similar to the affinity neck it had before except the frets are a bit bigger/taller and the width at nut is 42mm more or less. It's a 2 piece maple neck/board and on the slimmer side. The neck had a tinted finish which has mostly been removed as it was quite sticky, thete are remnants of it on fretboard but you cant feel it- whole neck has been sanded and polished with micro mesh pads and feels really smooth. It's got a bone nut, vintage style tuners with conversion bushings and frets have been levelled and dressed. Plays really nicely.
Original toploader bridge but have changed the saddles for steel ones.
Has the original 250k pots but have fitted a 4 way switch and iron gear steel foundry pickups.
Bit of a chip in finish around neck pocket and a dent/gouge in wood around the new metal jack plate- it fell and the original plastic one cracked.
Nice tele though, plays and sounds great and feels quite light.
Looking for £130- can post for a tenner.
I'm in SE London
Bump for a really nice guitar. If you were thinking of getting an affinity might be worth looking at this first
