Looking for an OD pedal that is quiet at a medium gain setting
ZoolooterZoolooter Frets: 887
edited September 2018 in FX
Way Huge Green Rhino appeals as it seems to have tweakable EQ controls and easy to set, but read that it can be noisy. Maybe that's just at extreme settings. After a low/medium gain pedal that can be smooth and fatten a strat or tele. Definitely don't want a pedal that introduces hiss when in the chain but not on.
Thoughts and recommendations welcome and appreciated.
  • ThorpyFX The Dane :)
  • fandangofandango Frets: 2204
    Thorpyfx Team Medic or Peacekeeper?
  • I found the Mad Professor Royal Blue had a really nice range of gain, good EQ, and was quiet. Also, very touch sensitive. I regret selling mine.
  • Try the Lunastone True Overdrive 2. That has a wide range of gain available, not high gain though and is voiced to be 'fatter', great with single coils and humbuckers.
  • Maxon od808 is great overdrive pedal
  • Xotic BB Preamp
    where in merseyside are you ? - got a few od / distortion pedals  you can try inc a way huge green rhino ; strymon sunset ; ts9 ; mooer flex boost / utlra drive / cruncher   ; BB +KOT mods clone ;  digitech blues screamer and there only the ones I can remember whilst still hungover ..
    most are true bypass - TS9 is exception afaik
    Im based crosby .. pm me
  • add Carl Martin Plexitone n Klon clone
  • AlvinAlvin Frets: 416
    Doesn't this describe a Zendrive ?
    Cheers for the offer, I'm in Grassendale near Liverpool Cricket Club. How do you find the Green Rhino for what I'm describing? Is it a quiet pedal?
  • ragingbenragingben Frets: 107
    Take a look at the Amptweaker Tight Drive Pro. For me it was the end of searching for overdrive pedals because it is so versatile it covers a lot of ground. It is quiet anyway but it also has a switchable noise gate built in.
  • NorthernStompsNorthernStomps Frets: 398
    Magnetic Effects Sandare has a huge gain range and powerful EQ. Well worth a look!
    https://www.northernstomps.com/magnetic-effects
    Facebook: @northernstomps // Instagram: @northernstomps // Twitter: @northernstomps
    Specialist Retailer Of Handmade British Stompboxes // https://www.northernstomps.com/
    Currently Stocking: Hudson Electronic/Raygun FX/Zander Circuitry/ThorpyFX/Rainger FX/Life is Unfair/ Magnetic Effects/Fredric Effects
  • ThorpyFX Peacekeeper can do exactly what you want and loads more!
    sorry for not getting back earlier - family bereavement ,,,
    I'll try it later this morning - what rig are you running ?
    what have you used previously as your comment re noise in the chain when not on indicates to me that you may have used a non true bypass pedal ?
    http://tonfaktor.blogspot.com/2008/08/mr-way-huge-on-various-bypass-methods.html ;
    edited October 2018
    Further to above - my Green Rhino mk11 no noise in bypass - beefs up low end, dial in to taste - upper mid range sweep works well .. tried with fat 50's and american std strat pu's .. neck n middle only as both guitars have humbucker treble pu's ..
    Their demos may give you more insight
    pm - if you want to come over - train cressington to crosby ..   round corner from stn ... most welcome
