I’ve recently bought a CE24 and it’s a 2016 model, so will have a Korean bridge and tuners.
Apparently, there’s no benefit in changing the tuners themselves, but I want to change the buttons purely for looks, and I want to go with real wood.
Does anyone have a definitive answer to which i need?
The guy from Crazyparts says I need the buttons that will fit PRS Phase 3/SE tuners.
I’ve also had someone say that Schaller M6 buttons in standard size are the ones to go for.
Any help?
I don’t have a gambling problem, I’m winning, and winning is not a problem for me. That’s like saying that Iron Maiden have an awesomeness problem.
https://www.touchstonetonewoods.co.uk/products/guitars-and-fretted-instruments/machine-heads-/-tuners/electric/schaller-machine-head-button-ebony-set-of-6-55861425638384/
I don’t suppose you could whip out a ruler and measure the width and height of a button?
Large would be 23mm x 16.5mm
Small would be 18.5mm x 14.5mm
It doesn't. IMO, the S2 series Phase 3 style efforts are not much better than the Jin-Ho items on the SE. The gear housings on the latter are bigger than the S2 type and have a lug for a locator screw.
My PRS SE guitars now all sport Gotoh SG381 machineheads. If any of them had a vibrato, I would have chosen the Gotoh Magnum Lock 'heads. These directly retrofit. Thus, in the event that you ever decide to sell the CE24, the modification can be reversed.
But it does require reading it yourself.
I can’t for the life of me see anywhere that has specs and sizes for the tuner buttons.
Are you saying that there are some tuners that will directly drop into a CE24 without modification?
I just looked up the Gotoh’s and they all have screws to attach to the back of the headstock, my ne has the pins.
My mistake. I was thinking of the SE Series.
My experience of Core PRS guitars is all on older examples. With one exception, these all left the factory with the "wing collar" 'heads, fastened by five screws. The one exception has keystone Kluson-alikes.
All this has done, has confuse me more! The picture above, you said they are Phase 3s? Aren’t Phase 3s the open geared set? The tuners on the CE certainly look just like the ones above.
Just ordered a set of Rosewood buttons from Crazyparts, and an upgraded trem from Wudtone.
