99% of everything you read online about the Drive channel on this amp and the Hotrod will be people telling you that it's near enough unusable... they're all wrong.
It's absolutely true that it doesn't sound like a Marshall, Mesa or other typical 'overdrive' amp - it's not meant to! It's meant to sound like an overdriven version of the clean channel, which is exactly what it does.
Very much so. You can keep the drive low and turn the master up to give a clean volume boost, or add a bit more drive and a bit less master if you want it dirtier.
You might find it easier to control with a little gadget that goes in the FX loop - the other usual complaint about these amps is that the volume goes from too quiet to too loud over a very short range of the control, which to an extent is true.
If you do find that a problem, this is what you want - http://thesuperheroesonline.co.uk/Fender-Hot-Rod-Volume-Pot-Module.html - the neatest and best of them, made by our very own @Danny1969.
That will also allow you to turn both channels up or down at the same time, so you don't have to re-adjust the balance between them.
