Any delay was coming from his PCM unit. Basically he uses three delays, which you hear in the left, right and centre.
Say you have the first delay set to 292ms you will hear this on the right, the second one would be 584ms, on the left, and the final is 888ms and you hear this in the middle. These are actual settings from the PCM 70.
If you're after cleans then either use a Fender Twin. For dirty rhythm go with a Marshall sound, for lead go with a boosted Marshall.
Good luck.
Some info about his Tambu tour gear at the bottom of this page. Rivera released a Luke Bonehead sig amp in 97, I think it's quite rare and valuable these days.
I've owned a Bonehead, strange sounding amp..
The only place that was fairly spot on was the HRI forum and it might have been on there that I read it.
I knew he used a W/D/W-setup, but the triple delay thing was new. I think I have a couple of patches with the stereo harmonizer panned left and right, so that might be a good place to start. I'll share if I end up with something usable...
There's a vid on youtube for the AX8 for a PCM type delay and its just a case of translating it into Helix speak - works a treat.
