Ooo... What is that?
My brother was chucking a load of old junk including an old 60s Bush radio which I took to have a see what's inside.....
Feel the mojo.... a Mullard OC71 =) !
I've pulled it along with an AC128 that was in there. The OC71 has low leakage (0.149) and good hFE (63.1). Might have to try it in my Hudson Broadcast build
  • GagarynGagaryn Frets: 1553
    Yup, I have my mothers old Bush (radio!) which also has OC71 in it, they were pretty common in transistor radios. My plan is to fit a DAB in it but so far all I've done with it is wire a 1/4 inch jack in and use it as a small portable amp. Sounds rubbish but in an amusing way!
  • lewismlewism Frets: 250
    I don’t think the AC128 will be original but those types of radio normally have an OC44, two OC45, an OC71, an OC81d and two OC81 - trouble is, it’s an absolute crapshoot as to whether they’ll be useful in terms of gain and leakage. You also see lots of weird and wonderful substitutions.
  • OctafishOctafish Frets: 1937
    No OC's apart from the OC71 (which has low leakage and good gain), a load of four leg AF117s though. The AC128 has low leakage, but just 32hFE. Maybe it's a replacement although the solder looked untouched and it's the old style can without the flared skirt.
