Audient ASP008 8 Channel ADAT Ultra-Linear Pre amp. Perfect condition
Very well looked after, comes with original box and everything as new. Amazing clear pre amp, great for studio.
Looking for £500. Cost me £1100 a few years ago.
Eight Channels of Audient Quality with ADAT!
The Audient ASP008 is a compact, 1U rack mount unit featuring eight high-quality mic preamplifiers developed from the microphone preamp design used in the acclaimed ASP8024 recording console. Implementing an 8-transistor discrete Class A front end with extended band-width and a noise floor close to the theoretical Johnson limit, the ASP008 offers amazingly transparent sound. Each preamp also features switchable input impedance, allowing you to explore the subtle variations in microphone character that are determined by output termination. For connection to a DAW or other ADAT-equipped gear, the ASP008 is loaded with ADAT outputs.
Audient ASP008 ADAT Features:
- Discrete Class A front end
- Switchable input impedance
- Two Instrument inputs
- Variable Hi-Pass filter on all inputs
- Line level input on all channels
- Phase invert on all channels
- Signal status indication
- ADAT Output
- DB-25 Input/Output
Pics available
