Peavey Vandenberg series 1 traded
USA Peavey Vandenberg series 1,rocket or Lazer (not sure which) red,Ebony board, Kahler killer 2700 trem,original hardcase,one chip on top thats been touched up thats is down to the wood could be drop filled i guess,odd mark here and there but otherwise in good condition. £550
There is plenty of info online about these but here are a few specs i have found.
The Peavey Vandenberg Signature guitar is a "made in the USA" super strat type guitar released in 1988. It distinguishes itself from other superstrats by a very unique look. It has a slightly arched top and "fiddle cuts" in the body. The lower cutaway also has an extra scooped cutaway for reaching the highest fret. The scale of the bolt-on neck is 24.75 inch (just like a Les Paul). The headstock is reversed and has a 3 degree tilt and matches the color of the body. The bridge is a
Kahler 2700 series (2710 Killer)licensed under Floyd Rose double locking tremolo. The pickups have an HS configuration with an Alnico bridge humbucker (14.67kOhm) and an Alnico neck single coil (6.47kOhm) with medium/high output both by Peavey. The pickups are both placed at a 2-4 degree angle (parallell with the body's bottom) to eliminate the string spacing problem when Gibson pickups are combined with Fender spaced tremolos.
Inlay color:
pearl
Link to photo's incase they don't work on here.
https://photos.app.goo.gl/XkVikKgQqKnEu3faAI will consider trades but mainly looking for a Plexi flavour valve head with a series fx,loop,a Marshall 1987x would work could add a bit of cash to.
Based near Wrexham North Wales
This is is a bargain good luck with the sale!
GLWTS
BRAVO!
* Hamer Watson, SS2, Vintage S, T62.
* Music Man Luke 1, Luke II
Please drop me a message.
Forum feedback thread. | G&B interview #1 & #2 | https://www.instagram.com/_harry_seven_/
