If you plan on playing gigs then moving up to a large amp would be advisable if you want cleaner tones at volume. The obvious two choices of you like the Princeton would be either of the deluxe amps. Over 20 watts so you will still get a great clean tone. If you want examples of how this could sound then do have a listen to JD Simo who uses a 335 into a Fender Deluxe Reverb.
You could have a look at the Marshall route as I personally find the cleans on a JTM45 as good as any amp and it takes pedals incredibly well. I use my semi with that amp all the time and I am never disappointed with my tone. It’s a different clean to the blackface or silver face fender sound. It’s thicker with more mids but to my ears superior.
If you want a combo instead of a head and cab then try out a Fender tweed Bassman.
If you just want an amp you can use at home and want cleans then either of the Princeton’s will work perfectly well.
Personally, I have a CS336 rather than ES-339, but it's the same tonal ballpark. I'm loving the blackface thing at the moment, though my main amp is a Badcat, which is majorly Vox-themed.
I find the mid heavy humbucker works well with the scooped mids blackface.
Agree with a comment above re the humbuckers: they are bright, crisp and far from mushy. Didn't sound bad through a Marshall plexi type of amp, not shrill but really not heavy, clear cut / SG like I would say.
https://imgur.com/gallery/4Eh7krf
Marshall JTM45
Fender Tweed Bassman
Fender Princeton 68
Laney Lionheart 4x10 combo
All of them sounded good as a good guitar can sound good through most amps.
The reason I like the Bassman is that the cleans are thick and the articulation of the guitar shines through. Plus when you dig in a little you get a bit of bite from the amp.
Great guitars though. A bit cleaner sounding than the 335’s I’ve tried.
