So you are just about to play a solo.....
HootsmonHootsmon Frets: 16010
and you have kicked on your OD for a leg up and now it's time to kick in that special delay setting to thicken up and add some depth and spaciousness to your solo voice......what is your delay Ms time,level and repeats for your magic stand out solo ?
Not looking for a time dependent dotted 8th or anything but a setting for all all tempos, general bread and butter, great solo tone
anybuddy?
tae be or not tae be
  • vizviz Frets: 10747
    Dunno the tempi or repeats but this is the generic delay setting I like tae use:
    2:20 and 5:20
    https://youtu.be/8B7hfx8Sgw4
  • CirrusCirrus Frets: 8495
    The first repeat happens after 50 milliseconds, the second repeat happens after 300.
    This is universally guaranteed to sound incredible.
  • ESBlondeESBlonde Frets: 3596
    I don't do numbers so much as what sound good. I play mostly live so set a generic single echo with about 3 repeats that goes well with pretty much anything in terms of lead work. Joe public don't know digital echo from tape and the concept of reverb would blow thier minds.
    Get a nice setting and play confidently. Sorted.
    Something I've never understood since getting in to the guitar is how can a guitarist set a delay time in milliseconds independently from the tempo of the song?
    If it's a very fast slapback delay it's not noticeable but if it's in the several hundred ms zone it's just going to be completely out of time with the song unless it's set specifically to be in time, either by calculating the BPM or adjusting it by ear for each specific song.
  • Did someone say 'solo'?
    hahaha
    I couldn't really make that out at first and thought it was just a man on the floor and I thought "time to get his wah going" then when I looked closer and noticed it was a wah it was hilarious
  • Only use delay on one song and its set to the song tempo.
    I sometimes think, therefore I am intermittent
  • EQ: more midrange
    delay: ?? wouldn't bother
  • prlgmnrprlgmnr Frets: 3993
    Lexicon circular delay. 292ms to the right, 584ms to the left, 888ms to the center.
    What do you mean you're not in stereo?
  • ICBMICBM Frets: 72764
    450mS, 2 or 3 repeats, just under 50% level for first repeat.
  • gusman2xgusman2x Frets: 922
    Delay on a solo???!!!!
    You're mistakes will be heard forever, forever, forever, forever....
  • octatonicoctatonic Frets: 33859
    anybuddy?
    What sauce do you put on every meal regardless of what you are eating?
    anybuddy?
    Delay isn't sauce, delay is salt.
    I missed this question earlier, but I’ve never used tempo-related delays. It doesn’t matter if it’s not in time with the song, it’s just an effect that adds space and fills out the sound.
    I like some pieces of music with a delay that’s in time, but that’s a different thing, it’s more like a second guitarist. I never play that sort of music myself though.
    The same applies to tremolo, it can either be in time or not, depending on how you want it to sound.
  • I use delay for rhythmic stuff and textural things, not cheesy 80's solos...
  • p90foolp90fool Frets: 31742
    I hate using delay, it ties me to obvious, safe scales as I'm always playing over my previous note.
    Better players than me seem to get around it, but I can't.
  • I use it quite a lot - an analog/tape style delay set on a relatively low level with 3 or 4 repeats that just blend in. I'd guess it's around 350-400 ms but I don't have a delay with time display so it's just a guess. There's no need to worry about fitting in with the track tempo because it's just a spacey mush and individual repeats are not clear.
    I've used more precise delay times in the studio to get that Edge-style doubling effect, but that's more for rhythm than solos obv.
  • GrumpyrockerGrumpyrocker Frets: 4162
    edited November 2018
    Lots. Big massive "I'm the 80s God" three repeats of sheer manly echo. As it should be.
  • Surely the point of adding delay to a solo is to add so much that individual notes become completely indistinct and you can batter the audience with a wall of oscillation?
    Just me then...
    I was looking at some Billy Duffy stuff, he often has two delays. As far as I can see the first one has all the knobs at 10 o'clock and the second one the same but the time moved to 2 o'clock. On a DD3 I'm assuming that's roughly a third and two thirds of 800ms ( you can do the maths but I'm going to say approximately 250 and 500ms). I think it's going through the longer delay first. Satriani does a similar thing, Google says 400 and 600 ms for him.
    Not really sure I get tap tempo unless you are Albert Lee or The Edge.
    I don't think I've plugged in my pedal board for about 6 months but that had one delay for slap and one for long delays ( probably 500ms or so) but the second as more of an ambient thing. Both together ( again long delay first after some experimenting) for being a bit crazier. Both dark analogue delays though.
  • The long delay setting on my Helix LT is:
    Time: 331ms
    Feedback: 40%
    Mix 35%
    Level: 0dB
    Trails: Off
    That's the delay I'm using for the solos in my recent post in the thread titled "Post live videos of your band here"
    But generally I tend not to use long delays for solos.
    It's not a competition.
