So I decided to see what my Yerasov combo would sound like through my AC30 speaker cabinet. I have had the AC30 modded so that I can unplug the speaker cable from a jack input on the underside of the amp. The Yerasov has the same arrangement stock.
So I simply connected the cable from the AC30 using a female / female adapter to a speaker cable into the Yerasov amp. Both are at 8ohm I think*. But no sound at all. I the tried the reverse - Ac30 amp in to Yerasov 1x12 no sound either. What am I doing wrong please?
*If they weren't and the AC30 was 16ohm I would have damaged the amp(?) and that hasn't happened so..
No, so plug up the speakers and then BEFORE inserting into an amp "plop" the plug across a PP3, an old, knackered one will do. No ploppy, NO connecty!
A PP3 battery? And what exactly do you mean by 'ploppy'?
As Dave said, don’t use a standard female-female connector for speakers, they aren’t reliable enough and could leave the amp with no load. Only the Neutrik one is any good.
If both amps still work OK with their own speakers then no harm has been done. It’s very unlikely unless the amp was really cranked up anyway.
Just remember not to keep the battery connected to the speaker for any longer than to hear the pop or see the cone move - it’s not good for either of them if you keep the current going for long.
