Stripping paint off a neck
jonnygreentreesjonnygreentrees Frets: 671
edited November 2018 in Making & Modding
I have an old Aria Pro II similar to this
Which has been sat in my loft for ages.
Originally the body was a horrible poly clownburst which I have sanded off but the neck is still painted and I don't fancy sanding it all off.
Will paint stripper work?
  • rexterrexter Frets: 369
    edited November 2018 tFB Trader
    Most likely (almost definitely) not... even the really aggressive stuff thats not sold in the shops won’t shift a 2k poly finish. I’ve actually started farming stripping out to a local company who specialise in it and the boss there reckons he has something that will remove a chemically cured modern finish but I haven’t taken him up on it yet. Still a little wary.
    for a neck like this your only option is sanding really. Not something I would do for the risk of damaging the carve and contours. Also would take a very long time!
    Custom colours, vintage restorations, high end guitar finishing
    www.rexterguitars.co.uk
    fair enough :(
    I might just paint over it!
  • I would recommend stripping it first as the build up of paint and finish may make is 'sticky' to play and the finish could be aesthetically unpleasant.
    Just take your time with some rough sandpaper or carefully with a razor blade to scrape it off
  • axisusaxisus Frets: 28339
    Yeah, I'd go sanding/scraping.
  • For a neck, I find sanding usually works.  Not always, but usually the coatings on the neck are lighter than on the bodies.
  • A heat gun, maybe?
  • SargeSarge Frets: 2403
    I've used a heat gun but only to gently soften the poly before scraping then sanding, be careful of any plastic binding if using this method.
