A Windows10 issue; had big problem at start-up today, very unexpected; OS not loading. Automatic repair started then screen went completely blank, not even blue!
So far I've had 12 hours faffing about.
What
seemed to have happened is that Win10 changed the name of one of the
drives to 'local disk' - I have no idea why or how - and that was
probably causing the problem...I think. Can anybody tell me if that was cause or an effect?
When it finally loaded (after some shut downs and reboots) I tried troubleshooters, various scans; some ran, some didn't.
Everything was very slow and I couldn't get Disk Management to come up.
I shut down, disconnected the offending drive's SATA lead from the motherboard and rebooted.
It took awhile but eventually told me it was scanning and repairing system reserved drive (F).
I discovered I'd disconnected the wrong lead but it didn't matter as now the drive was showing the correct name. Shut down, reconnected lead, rebooted and it worked ok again.
So I decided to restart. Took a long time, once again it scanned and repaired system reserved drive (F), and once again it has renamed my H drive to local disk, thus making it inaccessible. And I can't get the Disk Management up either, once again.
WTF? I'm going to shut down and reboot again next.
Please note I am no expert and when I tried to use the SFC command it told me I had to run it as an administrator which I don't know how to do. Probably lucky for me I couldn't do that then.
Damn thing has a mind of its own. How do I make myself the administrator of my own bloody PC? Shouting at it didn't work!!
Many thanks in advance for any help.
I think the local disk is likely to be a red herring. It might even have been a feature update going on slowly, but diagnosing the cause without digging through event logs etc and having much more info is going to be ... amusing.
https://answers.microsoft.com/en-us/windows/forum/windows_10-security/chinese-application-preventing-shutdown/04e95ce0-0c1b-4028-8400-dadcdceac288?auth=1
I googled 'TrusteerNotificationAreaMSGbox'
Trusteer is a right PITA but is probably not the underlying problem here.
Personally, given the unknown starting position, your own stated lack of knowledge, the reasonable assumption that there's been a fair bit of random poking going on based on random Googling, and the fact that the system appears to be Very Upset Indeed I would suggest one or two courses of action:
- take it to someone you know and trust who knows about this stuff, and get them to look at it (possibly with you, as a learning exercise if you're interested in knowing more for the future)
- start again from scratch on a clean system, and, as you suggest, use a USB caddy to recover any data that you haven't got backed up (although obviously you will have everything you care about backed up )
That's not meant to sound harsh, just trying to avoid giving advice that could lead to an even bigger FUBAR than you've got right now
On Disk Activity it's the "Highest Active Time" that matters, more so than the basic i/o. If you're at 100% Highest Active Time and you have a queue that's regularly significantly over 1, then the disk is a bottleneck.
Sorting by write activity will tend to show you which process(es) are the culprit. Ticking the box by the process will then filter the activity down to just the ticked items. You then sort that by Write activity too and see what file(s) are being hit, and that can give you a big clue as to whether it's just normal Windows "stuff" or something that you can deal with more directly.
- Political Correctness
- Prostate Cancer
- Police Constables
?Seriously: If you value it, take/fetch it yourself
Now they're insulted by using the much milder Orrificers, I mean Officers.
There's no 'punk' in the world anymore.
