Same goes for power, it’s easier than you think to wire positive and negative back to front sometimes. Sounds stupid but I’ve done it a shameful amount of times. Also make sure you’re not using an AC power supply, that’ll fry your pedal most of the time.
For transistors and chips use sockets, those can get fried by using too much heat, or heating them for too long. It’s much easier to swap them around if you have them in the wrong way (again, that happens all too often, especially if you’re me) and you can also easily try out different types and combinations without having to desolder everything.
Get yourself a cheap digital component checker, I got one on ebay for about £15 and it’s been a life saver. You’ll be able to easily check your resistors/capacitors etc are the correct value if there’s any doubt.
I said maybe.....
