Two-Rock Coral Head 40 w - £2,400 - TRADED
Thinking of moving on my much loved Two Rock head.
Very well looked after amp and not a mark on it. With footswitch.
The coral was the replacement of the Custom Reverb Signature.
Collection preferred. No trades.
The Coral delivers superb cleans with plenty of headroom, along with an ODS style cascading gain structure for sweet 'Dumble' overdrive. Shared EQ with the standard Two Rock shift switches and awesome tone stack bypass. Reverb send and return for both channels. Footswitch for overdrive and EQ bypass. Perfect for Mayer and Schofield tones - works great with and without pedals!
Two Rock Coral Specs:
- Output Power: 40W
- Resistance: 2 x 4 ohm outputs for 2 cabs at 8 ohms, or 2 x 8 ohm outputs for 2 cabs at 16 ohms
- Tubes: 4 x 6V6
- Reverb: Reverb send and return for both channels
- Dimensions: 20 5/8" wide x 12" tall x 10 1/2" deep
- Weight: 47 LBS
- Loop: Passive effects loop
- Features: Reverb send and return, Dual channel amp with shared EQ and cascading gain, Treble, Middle, Bass EQ controls with boost switches and EQ shift switch, Presence, Gain, Volume, and Overdrive gain and volume controls, Cathode bias and fixed Bias switch
https://imgur.com/a/RGF7ODe https://imgur.com/a/bp3UQDJ
