Soz, think this could be a long story but here goes.......
About five or six years ago I had all the windows in the house replaced by a reputable (or so I thought) and local company. I know people who have used them and I've not heard any complaints.
The installation was a bodge job in my opinion and I had to call them back many times due to excessively loud wind noise after the installation - even a mild breeze would result in the windows howling.
After about the fifth or sixth visit I finally spoke to somebody in the company who seemed to know what he was talking about - when the new windows were installed the installers left the cavities open and just covered over them internally with uPVC cladding so when breeze entered through the air bricks it was blowing through the cavity and finding its way out via the new frames somehow.
He rectified the situation by removing all the cladding and squirting copious amounts of expanding foam into the cavities before tidying it all up again. This made things better but didn't eradicate the problem completely. He then added an extra piece of external quadrant around the frames which has finally made the wind noise abate, or as good as.
That's just a bit of a back story and not the reason I'm posting - I just thought it might serve useful information for my next question/problem.
Despite the windows being A++ energy rating (or that's what they claimed them to be) I get an awful lot of internal condensation on the window panes, even when the weather is only slightly chilly outside - I'm talking about 10C or so and condensation will start to form. The old windows used to as well but they were cheap, old, and well shot when I moved in.
I keep the house well ventilated and even keeping the bathroom window open on night vent works well at keeping the room ventilated and dry, so the other rooms shouldn't hold excessive moisture.
I also don't notice any other houses in the neighbourhood having condensation on the windows, and I do look. In any other house I've lived in I've never noticed a similar problem, even comparing to my folks house whose windows are 30+ years old and they don't have any issue with condensation forming.
So, naturally I'm starting to believe that the windows have a massive thermal bridge somewhere in the design and the warm air inside the house is condensing on the cold glass surface, particularly around the edges of the windows, the bottom edge of the glass can have several inches of condensation on a really cold morning.
That can't be right for a modern double glazing system, can it?
In anticipation of being asked, none of the windows have trickle vents - but then neither do my folks windows and as I've stated, they don't get any condensation at all.
The windows are still under guarantee so I'm wondering whether this is normal and whether I should make myself a nuisance to the window company again.
TIA
EDIT: If I leave the windows open on night vent (second locking position) they will still condense.
Turns out there is an H in Haych! ~ Sporky
Bit of trading feedback here.
Hmm, interesting stuff - thanks for the linky. It's helped to explain a few things.
I have been thinking of purchasing a dehumidifier for a while. If the issue I'm having is a natural phenomenon of better glazing then I will be acquiring one in the next few weeks I reckon.
Thanks
If you then find humidity is high you can either take more action to reduce it or (the more expensive option) get a dehumidifier and run it frequently.
If the hygrometer shows the relative humidity to be low/medium you can then look at the effectiveness of the double glazing. If the sealed units are not misted inside they should be OK. Did your d/g units have Argon fill?
Our double glazing only shows internal condensation if the outside temperature is very low (below zero) or when Mrs 66 has four saucepans boiling on the hob with the extractor fan switched off because "it's too noisy"
Another great idea, cheers
Condensation and high humidity were an issue in my house until recently. An old one with solid walls, modern double glazing and poor ventilation
A PIV unit in the loft has completely solved it. Humidity has been consistently 50-60% since it was installed - we have no condensation, even on the single glazed original external door
Instagram
Offset "(Emp) - a little heavy on the hyperbole."
Did you fit it yourself or have someone in to do it? What sort of cost are you looking at?
If so this will potentially create a cold bridge. Ideally the window should be set across the cavity with thermal closers around it.
If you have an insulated cavity the outside skin is cold.
Say 25mm of insulated plasterboard all the way around, skim and paint. That would partially stop the cold bridge.
On top of that you could clad around the window externally with plastic or timber. Anything that adds thermal capacity to the cold spots will help.
I think you need to try to drive the dew point back towards the outside. At the moment cold air is meeting the warm air in your house and hence some of the moisture.
Google 'Dew Point in houses' for a better understanding.
