Reverb and delay pedal
BarneyBarney Frets: 616
If decided I don't use many Fx at all so looking for a pedal that will do both reverb and delay as the amp dosnt a reverb ...does anybody have any reccomendations
  • TheMarlinTheMarlin Frets: 7915
    edited December 2018
    If you’re really into your delays, then consider a Strymon El Capistan.  If you want somthing more straight ahead, try Keeley Caverns Or Memphis Sun
  • simonksimonk Frets: 1467
    EQD Dispatch Master
  • Look at Zander Circuitry Tape Deck, nice delay. Lo-Fi.
    We are a UK based, family run company retailing guitar effects pedals and accessories online.
    https://www.breakthemachine.co.uk  connect@breakthemachine.co.uk
  • Keeley Caverns is a fairly obvious one.
    CKK do the Space Station Pro which is less money.
    Or the EQD Avalanche Run V2 if you want to spend lots of money and like wacky noises.
    The Keeley Delay Workstation has multiple delays and multiple reverbs ( you can use one of each at a time). Good old fashioned knob twiddling and tap tempo.
    Mooer Ocean Machine if you like ambient noises on a budget.
    EQD Dispatch Master is a very simple 4 knob pedal.
    Boss RV3 has delay, reverb and combined modes.
    That’s all the ones I can think of!
  • ....thought of another!
    Mooer Echoverb. That’ll be the smallest and cheapest option.
  • BarneyBarney Frets: 616
    Thanks everybody ..I will check these out :)
  • gringopiggringopig Frets: 2648
    edited July 2020
  • JezWyndJezWynd Frets: 6096
  • timbuk02timbuk02 Frets: 272
    Theres aways the Zoom MS-70CDR  - a lot going on in one pedal
  • cbakaycbakay Frets: 67
    The El capistan. Great delay, very versatile. Easy to dial in and get the hang of. It has a built in spring verb which is good nuff but has no flexibility to it other than 0 to 10.
