How do you remove a third party from a group message? Or does the individual need to remove themselves?
e.g. if I start a discussion with 5 other FBers, and maybe add a couple more in along the way, and then one of them wants to leave because it's no longer relevant:
- can I remove them as the discussion originator? (If so, how, 'cos I can't see a mechanism)
- do they just need to use "Delete Conversation" at their end? (which presumably deletes the conversation for them, but doesn't unilaterally destroy it for all the other participants?)
- do the rest of us need to start a new conversation that doesn't include the people who want out?
I'm assuming it must be the middle option, but thought it wise to check.
No, it's someone who's requested no more notifications. But I still think wants access to the messages. So I'm not sure how that will work, or indeed if it's something I can control. A learning opportunity!
Unfortunately, you can't both remove yourself from a conversation and keep the conversation in your history. Thank the Vanilla devs for that little piece of genius.
A much better way to have that sort of multi-way conversation is simply to run it as a thread in public, assuming you're not bitching and moaning about people in private
(No, it's not a bitch-fest, just an organisational convo that doesn't have the capacity to be come one, come all, unfortunately).
