Bl**dy hell! expensive pots!
axisusaxisus Frets: 28347
I'm resurrecting my old Graphtec Ghost system for the headless guitar that I am building. The volume pot for the midi and also the acoustic one have gone a bit flaky, which is annoying. I thought I'd take a look at replacements, and they are £30 and £53 quid respectively!
Hmmmn .... think I'll make do.
  • What's flaky, you mean noisy? Intermittent?
  • axisusaxisus Frets: 28347
    Acoustic volume OK up to 9 but then cuts out completely if you get to 10.
    Midi volume seems to lose something from the midi sounds past about 7.
  • ICBMICBM Frets: 72726
    What value are they? There’s no sensible reason they should cost that much.
    edited December 2018
    Get one of these and a standard pot, or if the cables aren't too short just use the existing ones.
    http://www.graphtech.com/products/product-detail/pe-5002-00-ghost-volume-pot-assembly?id=987f34d6-ae0b-4362-99f9-7c74112b9505
    The cheaper one is actually listed as 250k linear so probably easy enough to replace. The other one doesn't give details of value. It is a bit different in that it is a push pull which gives you two different tones. Quite nice but I can live without that feature.
  • SporkySporky Frets: 28790
    While I don't necessarily disagree with you, I think they come with little wiring harnesses on them.
  • FunkfingersFunkfingers Frets: 14594
    Probably some buffering components involved too.
