I'm having an issue with my Les Paul. Last year I had it set up with a full fret dress and recrown - it was playing great, sounded great etc. etc.
More recently though I've noticed a lot of fret buzz and choking on the high e and b strings around the third fret - that's just the fretted note, not bending the string or anything.
I've just checked the neck relief on the treble side and using the old 1st fret, body fret method I can't detect any relief at the 7th fret, and I certainly can't get a 0.05mm feeler gauge between 7th fret and high e string.
On the bass side of the neck there's about 0.10mm clearance at the 7th fret using the same 1st fret, body fret method.
Is it perhaps time to back the truss rod off a tad? Or has the neck twisted a bit, since there's clearance on one side but not the other?
Turns out there is an H in Haych! ~ Sporky
Bit of trading feedback here.
Imagine a clock face, so 12 -11 is all that is required - slacken it - You can always do more later if required
I use the Low E string as my guide - left hand on 1st fret and at the same time, with the right hand pivot thumb on the last fret and reach over to view the gap on the 12th fret - Hope that makes sense - You can use a capo on the first fret if you like - then look for a slight gap, barely visible at the 12th fret - How big a gap you require will depend on if you pick/stroke gently or more aggressive/positive - And to a degree what level of 'buzz' you tolerate as some don't mind a touch as they prefer a shred low action
Yet I would expect some relief on both sides - There is a chance the 3rd/4th fret might be to high, but you mentioned a fret dress - However the fret might have 'popped'out a touch
If you sight down a guitar with a headstock-end truss rod adjustment from the headstock towards the body you will often see the head is rotated slightly anticlockwise, this is the reason.
